Hi all, i'm using infragistics ver 6.3 to generate webcharts(Infragistics2.WebUI.UltraWebChart.v6.3,
Version=6.3.20063.53 and UltraChart.DeploymentScenario.Scenario="Session"), and sometimes(extremely random), i get
the infamous "access denied" error image.
Then after a search, I read this kb:http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2041
I've a mixed scenario with a pure asp page with four charts(generate them by calling aspx pages obiouvsly).Then I try to turn every caching stuff off.
On pure asp page:response.expires = -1500 response.AddHeader "PRAGMA", "NO-CACHE" response.CacheControl = "PRIVATE"response.Buffer=False
On asp.net pages(chart generating pages):protected void Page_Load(object sender, System.EventArgs e) { Response.Expires = 0; Response.Cache.SetNoStore(); Response.AppendHeader("Pragma", "no-cache"); Response.Cache.SetCacheability(HttpCacheability.NoCache);
But still no luck...
Any suggestion?
Here are some addictional question:
1)There is a way to inercept the "access denied image" via javascript before diplaying it?I've seen that the output of a "good generated chart" is nearly the same of a "bad generated chart"i.e.<img style=''src='ImagePipe.aspx?ChartID=mychart_Base&KxRx=0x04813>
2)There is a way to change the "acess denied" image with some sort of custom image/custom text?
3)The last version of UltraWebChart(8.1.20081.1000) may solve the problem?
Thanks in advance
it's hard to tell what is failing. if you want to try something to diagnose the problem, you could set up a test that puts an object like a DataSet into the session, then requests it later from another page.
at some point this object might be cleared from memory; for example if ASP.NET's memory usage gets to a certain point, the process will restart (this is to prevent memory leaks) and everything in the process memory will be gone.
considering the ineffectiveness of all the proposed solutions, I would try to implement vemistemi's workaround: http://forums.infragistics.com/forums/p/5477/26710.aspx#26710
I tried all the solutions and the only working one is to use the file system deployment scenario. It's not acceptable but it is my only solution.
there are many suggestions given in this thread to solve the problem, so you might want to look through and try some of the proposed solutions. but most importantly, make sure you are using the latest available hotfix for 7.2.
Are you able to fix the issue? I am getting the same error. I am using 7.2 verison.
ASP.NET has a feature where if memory usage gets too high for a web application, the worker process restarts itself. This is the framework's way of protecting against memory leaks. In this event, your session state might be lost at that moment; but it should be very rare. That is one possible reason for this problem, but it's just a guess.
Make sure you install the service pack for the version of the .NET Framework you are using on the web server; that might also resolve the problem.
I noticed you were using a hotfix of 7.2, but one that's almost a year old (7.2.20072.1063), so maybe try upgrading to a later hotfix. After looking at the source code changes in the past year, I don't think this is the solution, but it might be worth a try.
