Hi All,
I am using WebAsyncRefreshPanel, UltrawebGrid and WebDropDown controls on page.I have input html button outside the WebAsyncRefreshPanel.WebGrid is inside the WebAsyncRefreshPanel.
I am using WebAsyncRefreshPanel content refresh event to call server side method asynchronously.From the dropdwon I select values and click on button which is outside refresh panel.I am calling content refresh server side event using this
var warp = ig$("<%=WebAsyncRefreshPanel1.ClientID %>"); if(!warp){return;} warp.refresh();Inside cintent refresh event I am calling BuildGrid functionI need dropdown values to pass to server and fetch dataprotected void wrappnlGrid_ContentRefresh(object sender, EventArgs e) { try { if (Session["BuildGrid"] != null) { pnlGridContent.Visible = false; if (Convert.ToBoolean(Session["BuildGrid"])) { hdnEditableRowIDs.Value = string.Empty; BuildGrid(); Session["BuildGrid"] = false; } else { Session["BuildGrid"] = true; } } else { Session["BuildGrid"] = true; } //if (hdnSaveOrBuild.Value == "BuildGrid") //{ // //status.Text = "wrappnlGrid_ContentRefresh"; // BuildGrid(); // hdnSaveOrBuild.Value = string.Empty; //} } catch (Exception ex) { string ErrorLocation = "NonWorkFlowSheetNoMaster.aspx.cs : wrappnlGrid_ContentRefresh()"; ClsErrorLog.LogError(ErrorLocation, ex); ErrorHandler.HandleExceptionNoRedirect(ex); } }
I am not getting values of dropdown inside build grid function private void BuildGrid() { try { pnlGridContent.Visible = false; int AccountId = 0; int YearId = Convert.ToInt32(ddlYear.SelectedItem.Value); int VersionId = Convert.ToInt32(ddlVersion.SelectedItem.Value); int DimensionId = Convert.ToInt32(ddlDimension.SelectedItem.Value); int UnitId = 0; string Template = ddlTemplate.SelectedItem.Value; string IdList = string.Empty; if (ddlTemplate.SelectedItem.Value.Trim().ToLower() == "account") { AccountId = Convert.ToInt32(ddlAccounts.SelectedItem.Value); IdList = hdnEntityValue.Value; } else if (ddlTemplate.SelectedItem.Value.Trim().ToLower() == "unit") { UnitId = Convert.ToInt32(ddlUnit.SelectedItem.Value); IdList = hdnAccountValue.Value; } bool IsTotalVisible = chkShowTotal.Checked; DataTable dtGrid = null; dtGrid = GetData(AccountId, YearId, VersionId, DimensionId, UnitId, Template, IdList); if (IsTotalVisible) { AddTotalRowAndColumn(dtGrid); } //status.Text = "BuildGrid"; //CreateTable(dtGrid); if (dtGrid != null && dtGrid.Rows.Count > 0) { //status.Text = "BuildGridNotNull"; ultNWGrid.Clear(); ultNWGrid.DataSource = dtGrid; ultNWGrid.DataBind(); pnlGridContent.Visible = true; } else { ultNWGrid.Clear(); ultNWGrid.DataSource = null; ultNWGrid.DataBind(); pnlGridContent.Visible = false; } } catch (Exception ex) { string ErrorLocation = "NonWorkFlowSheetNoMaster.aspx.cs : BuildGrid()"; ClsErrorLog.LogError(ErrorLocation, ex); ErrorHandler.HandleExceptionNoRedirect(ex); } }Can anybody please help me out (ddlYear.SelectedItem.Value) to get value
Hello Charles,
The issue happens becuase you are accessing the SelectedItem inside ContentRefresh event of the WARP.
I suggest you doing post back.
Another option is setting the ID of the WebDropDown as RefreshTargetIDs and setting the RefreshInterval to zero which I strongly do not recommend you.
<igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Height="20px"
Width="80px" OnContentRefresh="WebAsyncRefreshPanel1_ContentRefresh"
RefreshTargetIDs="WebDropDown1" RefreshInterval="0">
Hope this helps
