I have WebHierarchicalDataGrids on a page that I would like to export to PDF, when do so, I receive the following error:
Error message: 'C:\ProjectPath' is not a valid virtual path. - /PageName.aspx
Source:
Class: VirtualPath
Method: Create
Help link:
Inner exception: System.Web.HttpException: 'C:\ProjectPath' is not a valid virtual path.
The grid and document exporter:
The grid and the document exporter are on the same asp:UpdatePanelThe grid does have a custom pager like the one of the samples (WebDataGrid)The grid uses a DataSet as DataSource that I rebind on every PostBack.
<ig:WebHierarchicalDataGrid ID="whdg" runat="server" Width="980px" AutoGenerateColumns="False" AutoGenerateBands="false" EnableAjax="true" EnableAjaxViewState="true" EnableTheming="true" EnableDataViewState="true" StyleSetName="Claymation" DataKeyFields="ID" InitialExpandDepth="0" InitialDataBindDepth="0" OnInitializeRow="whdg_InitializeRow" OnColumnSorted="whdg_ColumnSorted">
<ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="300" SlideCloseDirection="Auto" SlideCloseDuration="300"/>
<AjaxIndicator Enabled="True"/>
<Behaviors>
<ig:Activation Enabled="false">
</ig:Activation>
<ig:Sorting Enabled="true" SortingMode="Single">
<ColumnSettings>
<ig:SortingColumnSetting ColumnKey="TipoImage" Sortable="true"/>
<ig:SortingColumnSetting ColumnKey="Usuario" Sortable="true"/>
<ig:SortingColumnSetting ColumnKey="FechaHora" Sortable="true"/>
<ig:SortingColumnSetting ColumnKey="Accion" Sortable="true"/>
<ig:SortingColumnSetting ColumnKey="Mensaje" Sortable="true"/>
</ColumnSettings>
</ig:Sorting>
<ig:Paging Enabled="true">
<PagerTemplate>
<ag:WebDataGridPaginacion ID="whdgPaginacion" runat="server" OnPageChanged="whdgPaginacion_PageChanged"/>
</PagerTemplate>
</ig:Paging>
</Behaviors>
<EmptyRowsTemplate><div style="text-align:center;width:980px;padding:45px 0">No hay datos disponible.</div></EmptyRowsTemplate>
<Columns>
<ig:BoundDataField Key="ID" DataFieldName="SeguimientoID" Hidden="true"/>
<ig:BoundDataField Key="TipoImage" DataFieldName="Tipo" Header-Text="Tp" Width="36px"/>
<ig:BoundDataField Key="Usuario" DataFieldName="Usuario" Header-Text="Usuario" Width="142px"/>
<ig:BoundDataField Key="FechaHora" DataFieldName="FechaHora" Header-Text="Fecha y hora" Width="140px" DataFormatString="{0:dd/MM/yyyy HH:mm:ss}"/>
<ig:BoundDataField Key="Accion" DataFieldName="Accion" Header-Text="Acción" Width="180px"/>
<ig:BoundDataField Key="Mensaje" DataFieldName="Mensaje" Header-Text="Mensaje" Width="452px"/>
</Columns>
</ig:WebHierarchicalDataGrid>
<ig:WebDocumentExporter ID="WebDocumentExporter1" runat="server" ExportMode="Download" DataExportMode="AllDataInDataSource" TargetPaperSize="A4" TargetPaperOrientation="Portrait" EnableStylesExport="true" Format="PDF"/>
Version: 10.3.20103.2105
Hi estanito,
This screenshot looks like it confirms the error, but it gives no help in identifying the code where it occurs. It seems to be a problem with styles. Do you have any custom css classes defined or just the ClayMation style set?
-Dave
I've upgraded to version: 10.3.20103.2120 and the problem remains.
I pass you a screenshot of a part of the IntelliTrace information.
Hi esanito,
I am not sure what could be the problem by looking at this code. I know we have released a more recent Service Release. It is possible that it has this issue resolved, but I am not sure. If you could attach a working sample, I will gladly take a look and submit a bug on your behalf if I can reproduce the issue.
regards,
David Young
