I have a WDT with a bunch of items in it. So many, that it has a scrollbar (I've set the height of the WDT to 300px).
If I select one of the nodes from code-behind. How can I get that node in the tree selected and scrolled into view?
I've figured out the selection part, but the user has to scroll the tree to see the highlighted/selected node.
- Jerome
Hello Jerome,
There is scrollIntoView javascript function
http://news.infragistics.com/forums/p/41411/230834.aspx#230834
In order to take advantage of it I recommend you handling Initialize client event.
On the server side you can select the desired item and check in the Initialize event if there are selected items.
function WebDataTree1_Initialize(sender, eventArgs) {
///<summary>
///</summary>
///<param name="sender" type="Infragistics.Web.UI.ControlMain"></param>
///<param name="eventArgs" type="Infragistics.Web.UI.EventArgs"></param>
//Add code to handle your event here.
var tree = $find('WebDataTree1');
if (tree.get_selectedNodes()[0] != null)
tree.get_selectedNodes()[0].get_element().scrollIntoView();
<ig:WebDataTree ID="WebDataTree1" runat="server" Height="100px" Width="200px" DataSourceID="XmlDataSource1"
SelectionType="Single" InitialDataBindDepth="3" InitialExpandDepth="3" OnUnload="WebDataTree1_Unload">
<ClientEvents Initialize="WebDataTree1_Initialize" />
<DataBindings>
<ig:DataTreeNodeBinding DataMember="Customer" TextField="CustomerName" ValueField="CustomerID"
Depth="1" />
<ig:DataTreeNodeBinding DataMember="Order" TextField="OrderID" ValueField="OrderID"
Depth="2" />
<ig:DataTreeNodeBinding DataMember="OrderDetail" TextField="ProductName" ValueField="ProductID"
Depth="3" />
</DataBindings>
</ig:WebDataTree>
protected void Button1_Click(object sender, EventArgs e)
WebDataTree1.ClearSelection();
WebDataTree1.Nodes[0].Nodes[2].Nodes[0].Selected = true;
WebDataTree1.ActiveNode = WebDataTree1.Nodes[0].Nodes[2].Nodes[0];
Please let me know if you have other questions.
