i am generating the webDataTree node dynamically
i have 525 TreeNode each node has image url.
It take 7-8 seconds to load the whole tree.
why does it take long time to load whole tree?
How can i improve the performance of tree to load?
I have code and when i run, program throw error: unable to evaluate expression because.......on top of the call stack.
protected void btnExportExcel_Click(object sender, EventArgs e) { try { string fileName = "ExcelReport"; eExporter.DownloadName = fileName; eExporter.EnableStylesExport = false; eExporter.DataExportMode = (DataExportMode)Enum.Parse(typeof(DataExportMode), this.rblExportData.SelectedValue); eExporter.WorkbookFormat = (Infragistics.Documents.Excel.WorkbookFormat) Enum.Parse(typeof(Infragistics.Documents.Excel.WorkbookFormat), this.rblExcelFormat.SelectedValue); bool singleGridPerSheet = (this.rblSheets.SelectedValue == "single") ? true : false; eExporter.Export(true,gridCallLog); } catch (Exception ex) { throw ex; } }
Hi again,
Can you please provide a sample with your issue so I can investigate further and hopefully provide you with a satisfying solution!
Actuly there are multiple section node
then each section has mulitple category node
and each category has multiple item node.
and each category has there own image.
i have 12 section node so i have 12 diffrent images,
only few section Category nodes images are diffrent otherwise all are some.
if i will count total different images.then i am using total 15 different types of images for nodes.
Hi, there,
Which version of the controls are you currently with, and does every node have a separate image or is it the same image for all?
Sincerely,
