HI there,
We have a webdatatree which we populate on the server and all is well. What I am having problems with though is actually forcing a nodeclick event (which will then raise a postback) from the client-side.
I've got the following code (after I find the node) which I know is being executed (i.e the node is highlighted in the tree once called). But no matter which events I try, the postback is just not happening. Ive tried calling toggle, update, and various combo's (as you can see below) but nothing happens.
var node = tree.resolveItem(nodeAddress);
if (node != null) {
tree.set_activeNode(node, true);
node.toggle(true);
node.set_expanded(true, true);
node._toggleClicked();
tree.updated();
tree._nodeClick(node, true);
Is there a simple method i've missed somewhere, all I want to do is call the click event.
Many thanks
Hello bartond31 ,
Can you please share your scenario regarding this?
As Lubomir has suggested the best choice is calling __doPostBack
The options regarding firing the event do the trick but it is not a standard thing using them.
If your purpose is just to raise a postback, why do you just call __doPostBack(treeId, some arguments)?
To fire just the event you can do:
1) tree
._raiseClientEvent('NodeClick','DataTreeNode',browserEvent,null
,node,node._get_address(),browserEvent.button);
You can pass null for browserEvent and 0 for browserEvent.button.
2) Another thing you can do is tree._onMouseupHandler(elem, adr, browserEvent)
elem is reference to node.get_element(), adr is reference to node._get_address(), browserEvent can be passed as null.
So 1) or 2) should do the trick.
Hope this helps.
Lubomir
