90
WebExplorerBar get selected item text from OnItemClick event
I am trying to get the text of the selected item when the user clicks on the item. I want to get this item text during a server-side ItemClick event. When I run my code the event triggers, but the ExplorerBarItemClickEventArgs e.Item is a null value and so is the WebExplorerBar1.SelectedItem.
Here is the code behind snippets:
    protected void Page_Load(object sender, EventArgs e)
        if (!Page.IsPostBack)
            // Group 1
            ExplorerBarGroup group = new ExplorerBarGroup();
            group.Text = "Folders";
            this.WebExplorerBar1.Groups.Add(group);
            ExplorerBarItem item = new ExplorerBarItem();
            item.Text = "Documents";
            group.Items.Add(item);
            item.Text = "Samples";
            // Group 2
            group.Text = "Drives";
            item.Text = "C:";
            item.Text = "D:";
            // Group 3
            group.Text = "Miscellaneous";
            item.Text = "Worksheet.xls";
            item.Text = "Pic.png";
    protected void WebExplorerBar1_OnItemClick(object sender, ExplorerBarItemClickEventArgs e)
        string temp1 = "";
        string temp2 = "";
        if (e.Item != null)
            temp1 = e.Item.Value.ToString();
        if (WebExplorerBar1.SelectedItem != null)
            temp2 = WebExplorerBar1.SelectedItem.Value.ToString().Trim();
Here is the ASP code:
<%@ Page Language="C#" MasterPageFile="~/MasterPageSystem.master" AutoEventWireup="true"
    CodeFile="contentHome.aspx.cs" Inherits="contentHome" Title="Home Page"  %>
<%@ MasterType VirtualPath="~/MasterPageSystem.master" %>
<%@ Register assembly="Infragistics2.WebUI.UltraWebGrid.v10.2, Version=10.2.20102.1011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %>
<%@ Register assembly="Infragistics2.Web.v10.2, Version=10.2.20102.1011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.NavigationControls" tagprefix="ig" %>
<asp:Content ID="Content1" ContentPlaceHolderID="ContentInfoPages" runat="Server">
    function itemClick(sender, args) {
        var item = args.getExplorerBarItem();
        item.set_text(item.get_text() + " - Clicked");
</script>
    <div style="margin: 20px 10px 20px 10px; text-align: center;">
        <div style="width: 99%;">
            <div style="float: left; background: #FFF000; width: 20%;">
                <ig:WebExplorerBar
                        ID="WebExplorerBar1"
                        runat="server"
                        AnimationDuration="200"
                        AnimationEquationType="Linear"
                        AutoPostBackFlags-ItemClick="On"
                        OnItemClick="webexbarFabSeries_OnItemClick"
                        EnableExpandButtons="true"
                        EnableSelection="true"
                        GroupExpandAction="ButtonClick"
                        GroupExpandBehavior="AllExpanded"
                        EnableViewState="true"
                        EnableAjaxViewState="true"
                        Width="99%"
                        StyleSetName="Office2007Black">
                    <AutoPostBackFlags ItemClick="On" ItemSelected="Off" />
                </ig:WebExplorerBar>
            </div>
            <div style="float: right; background: #00FF00; width: 80%;">
                <div style="background: #FF0000; width: 99%;">
                </div>
                <div style="background: #00FFF0; width: 99%;">
                </div>
            </div>
           <div style="clear: both;">
            </div>
        </div>
    </div>
</asp:Content>
