I have an application and using UWG 10.3 it works fine in safari under CLR 3.5, however I have upgraded the project to 4.0 and now the grid does not show any styling and some functionlity is lost such as clicking buttons within the grid.
Any ideas as to why this is happing or help to work around this would be appreciated.
Hello Greg,
Thank you for posting on our forums.
Officially Safari is not supported by UltraWebGrid component, I recommend use WebDataGrid either WebHierarchicalDataGrid. Supported environments: http://es.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
Live samples with WebDataGrid and WebHierarchicalDataGrid : http://samples.infragistics.com/2010.3/WebFeatureBrowser/Default.aspx
Hope that helps.
