Hi there,
I'm having a difficult time getting the WebHierarchicalDataGrid to work properly. I've added one to a test page and without any code in the code behind file to bind any data to it, I get this error message:
I initially had tried binding some items to the collection, then leaving the call to databind out, then finally removing all code from the code behind and I still get this error. Does anyone know what's causing it? Code below - it's pulled directly from your samples page.
<ig:WebHierarchicalDataGrid ID="dg" runat="server" AutoGenerateColumns="false" AutoGenerateBands="true" InitialExpandDepth="0" InitialDataBindDepth="-1" Height="450" Width="700px" DataKeyFields="SupplierID"> <ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="300" SlideCloseDirection="Auto" SlideCloseDuration="300" /> <Columns> <ig:BoundDataField DataFieldName="SupplierID" Key="SupplierID" Header-Text="Supplier ID" /> <ig:BoundDataField DataFieldName="CompanyName" Key="Company" Header-Text="Company" Width="230px" /> <ig:BoundDataField DataFieldName="ContactName" Key="Contact" Header-Text="Contact" Width="150px" /> <ig:BoundDataField DataFieldName="Region" Key="Region" Header-Text="Region" Width="80px" /> </Columns> </ig:WebHierarchicalDataGrid>
Thanks!
http://blogs.infragistics.com/forums/p/34316/186308.aspx
The last entry in the above link seems to be written by the ONE knowledgeable person at Infragistics.
For us, it turned out we had a reference to <%= Page.ResolveUrl("~/../Common/jquery-1.7.1.min.js") %> in a <script> tag in the <head> section. Once we moved it out of the <head> and into the <body> wrapped in a <div runat="server"> the error went away.
Crazy stuff.
I'm seeing the same issue described in this thread.... in Infragistics4.Web.v11.1, Version=11.1.20111.2135
does each script need it's own div wrapper, or can several scripts be grouped in the same div?
Yep, that did the trick. Sorry for the late reply - was on vacation. Thanks!
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Hello Kslone,
Do you have a script tag on the page, in which you are having code blocks (<%= %>)? Would you test if you will continue getting this error if you delete (not just comment) the line?
If this is the case, you will stop getting this error if you move your script within an element with runat=”server” attribute:
<script type="text/javascript" language="javascript">
</script>
</div>
Hope this helps.
Lyuba
www.infragistics.com/support
