Hi All
Problem: Given the example project attached, when I load the page the grid is displayed correctly but if I change a value of an cell the OnUpdateCell event is not fired and the async postback results in a "No Data To Display" error message.
Setup: Windows 2008 rc2, IIS7, asp.net 3.5.1, Infragistics10.3
Alternative setup:On same host but run from within VisualStudio the problem disappear.
Cheers
René
Answer is to enable viewstate on webapp
Merry Christmas
I got a little closer now, the problem only occurs when I create a web application underneath a crm 4.0 web application. If I create a new website and deploy the test application there it works fine.
Anyone with crm 4.0 and infragistics experience?
I may add that it is a 64 bit machine
