80
Cannot dynamically Render Required Field Validator & a mandatory symbol
Unable to render a Required Field Validator while preparing a Custom Control inheriting from WebTextEditor.
It is displaying the following errors
1. Required a script manager in the page.
After adding a script manager it is displaying the following error now.
1. Unable to find control id 'CustomTextBox1' referenced by the 'ControlToValidate' property of 'rfvCustomTextBox1'.
Custom Control Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Web.UI.WebControls;
using System.Drawing;
using System.Web.UI;
using System.ComponentModel;
using Infragistics.Web.UI.EditorControls;
namespace CustomControls
    [ToolboxBitmap(typeof(WebTextEditor)), ToolboxData("<{0}:CustomTextBox runat=server></{0}:CustomTextBox>")]
    public class CustomTextBox : WebTextEditor
        private RequiredFieldValidator requiredFieldValidator;
        private ValidatorDisplay _display;
        public CustomTextBox()
        public virtual bool EnableRequiredValidation
            get
                object obj = this.ViewState["EnReq"];
                return (obj != null && (bool)obj);
            set
                this.ViewState["EnReq"] = value;
        public virtual string RequiredFieldValidatorErrorMessage
            get
                object obj = this.ViewState["rfvErrMsg"];
                return (obj != null ? Convert.ToString(obj) : null);
            set
                this.ViewState["rfvErrMsg"] = value;
        public virtual string ValidationGroup
            get
                object obj = this.ViewState["valGrp"];
            set
                this.ViewState["valGrp"] = value;
        public virtual string RequiredFieldValidatorInitialValue
            get
                object obj = this.ViewState["rfvIniVal"];
            set
                this.ViewState["rfvIniVal"] = value;
        [Category("Validation Properties"), Description("Display Validation Message with Validation Control"), DefaultValue(ValidatorDisplay.None)]
        public virtual ValidatorDisplay Display
            get
                return this._display;
            set
                this._display = value;
        protected override void OnInit(EventArgs e)
            base.OnInit(e);
            ValidateControls();
        private void ValidateControls()
            if (EnableRequiredValidation == true)
                this.requiredFieldValidator = new RequiredFieldValidator();
                this.requiredFieldValidator.ID = string.Format("rfv{0}", this.ID);
                this.requiredFieldValidator.ErrorMessage = this.RequiredFieldValidatorErrorMessage;
                this.requiredFieldValidator.ValidationGroup = this.ValidationGroup;
                this.requiredFieldValidator.ControlToValidate = this.ID;
                this.requiredFieldValidator.InitialValue = this.RequiredFieldValidatorInitialValue;
                this.requiredFieldValidator.Display = this.Display;
                this.Controls.Add(requiredFieldValidator);
        protected override void Render(System.Web.UI.HtmlTextWriter writer)
            if (EnableRequiredValidation && this.requiredFieldValidator != null)
                this.requiredFieldValidator.RenderControl(writer);
            base.Render(writer);
WebClient
<asp:Content ID="ContentPlaceHolder1" ContentPlaceHolderID="MainContent" Runat="Server">
    <table>
        <tr>
            <td>
                <UPP:CustomTextBox ID="CustomTextBox1" runat="server" EnableRequiredValidation="True"
                    RequiredFieldValidatorErrorMessage="Enter Value" ValidationGroup="abc" />
            </td>
        </tr>
        <tr>
            <td>
                <ctl:ctlbutton id="CtlButton1" runat="server" text="Click Me" causesvalidation="true"
                    onclick="CtlButton1_Click" validationgroup="abc" />
            </td>
        </tr>
        <tr>
            <td>
                <asp:ValidationSummary runat="server" ShowMessageBox="True" ShowSummary="False" ValidationGroup="abc">
                </asp:ValidationSummary>
            </td>
        </tr>
    </table>
</asp:Content>
The above custom control CustomTextBox is working fine if it is inherited from Dotnet 'TextBox' Control.
Please help me in this issue as early as possible.
In addition to the above logic in customTextBox want to render a mandatory symbol next to the CustomTextBox control.
Parents
  • 24497
    Hi Govind,
    The WebTextEditor was not designed as a container and adding a dynamic child breaks logic.
    I suggest you to add dynamic validator to form, but not to editor and do not use "Render" or other methods of editor to render validator.
    1. Remove protected override void Render
    2. Replace
      by
      this.Page.Form.Controls.Add(requiredFieldValidator);
    I can also suggest to add/create dynamic validator within PageLoadComplete, but not within this.OnInit.
    Something like
      base.OnInit(e);
      this.Page.LoadComplete += new EventHandler(this.ValidateControls);
    private void ValidateControls(object sender, System.EventArgs e)
Reply Children
No Data
