We have a strange behavior: when is made click to the next cell from a grid, the cell is activated and selected immediately, but if is made click on a cell before the current one, the cell is activated only at the second click.
Did you met a behavior like this? Can you suggest something?
Lidia.
This problem appear only in IE, in Mozilla is ok.
Ok, this bug can be seen also if is presses a previous cell from grid, on some portion without text. I sow this behavior also on the online samples.
Please tell me if this problem can be resolved on the next release. Now we are on the point to use gridview from microsoft. Anyway, I can say that the support is worst as from C1. The control was good only to impress the bosses but how to put in production with bugs?
Best regards.
As you see, it's a little bit stress about this issue. Can you confirm if in the last release this problem is resolved?
Now, we use the version 10.1.20101.1011, assembly Infragistics2.Web.v10.1.
Thanks.
I can't believe that isn't any answer. This is for shore a bug in control.
I forgot to mention that the cells are empty. When the cells, contains values, is ok the selection, only when the cells are empty is not ok. Can you help? Please, is not so user friendly. For our case, it was decided to have empty cells instead of values 0 at the begin.
