Hi , i have a webdatagrid with my custom dataset bind at runtimefirst i writeWebDataGrid1.ClearDataSource()WebDataGrid1.DataSource = dt_UserWebDataGrid1.DataBind()and a custom paging control when i click now on the button next page i got the following error
Runtime Error in Microsoft BLOCKED SCRIPT Sys.WebForms.PageRequestManagerServerErrorException: I found several controls with the ID it0_0. FindControl requires unique IDs for controls.I have found thishttp://news.infragistics.com/forums/p/32705/178360.aspx#178360iam use currently 10 vol 3i have tryed thishttp://forums.infragistics.com/forums/t/30834.aspxbut when i check the postback and not build up the grid the grid are empty.i mean that this error occurs since volume 3.
on first run the data will be fine, but when i click on the paging the above error appears.could anyone help me?
Hello Martin,
I created a support ticket on your behalf to investigate this issue further.
Lyuba
Developer Support Engineer
www.infragistics.com/support
