1840
Navigate to tab in JavaScript not work in Firefox or Safari
i use a Page with a  with following tab control (Version 10.2 Clr4.0
<ig:WebTab ID="WebTab1" runat="server" Height="700px"  Width="100%"
            ScrollButtons-AutoHide="False" meta:resourcekey="WebTab1Resource1">
    <tabs>
        <ig:ContentTabItem runat="server" Text="Druckversion" AutoSize="True"
            meta:resourcekey="ContentTabItemResource1">
        <Template>
            <iframe src="Detail_Print.aspx"  height="800px" width="100%" id="ifrm_Detail_Print"></iframe>
        </Template>
        </ig:ContentTabItem>
        <ig:ContentTabItem runat="server" Text="Adressen" AutoSize="True"
            meta:resourcekey="ContentTabItemResource2">
         <Template>
            <iframe src="Adresse.aspx" height="800px" width="100%" id="ifrm_Adresse"></iframe>
        </Template>
        <ig:ContentTabItem runat="server" AutoSize="True" Text="Tarife"
            meta:resourcekey="ContentTabItemResource3">
        <Template>
            <iframe src="Tarif.aspx" height="600px" width="100%" id="ifrm_Tarif"></iframe>
        </Template>
    </tabs>
<ScrollButtons AutoHide="False"></ScrollButtons>
</ig:WebTab>
On the first page i use an ImageButton to navigate to an ohter tab. The JavaScript Code is:
               var WTab = null;
               function WIB_Change_Adr_Click(obj, args) {
                   if (WTab == null) {
                       WTab = parent.$IG.WebTab.find("MainContent_WebTab1");
                   if (WTab != null) {
                       WTab.set_selectedIndex('1', true, e);
                       WTab.set_activeIndex(1);
In IE the navigation to Tab 1 works well, in other browsers nothing happens (not even a js-error).
Any knowledge what went wrong?
  • 24497
    I suggest you to use $find(id). I tested following within ContentUrl of tab and it worked in all browsers.
    function click1()
     var win = parent;
     if(win && win.$find)
      var tab = win.$find('WebTab1')
      if(tab)
       alert('selected tab:'+tab.get_selectedIndex());
      else
       alert('no tab');
     else
      alert('no javascript in parent');
    I expect that same codes will work if explicit iframe is used instead of ContentUrl
