How I can Make any column fixed in the webgrid so that the column itself does not allow dragdrop and also disallows the drga nd drop of others column over it.
also i want to make this column fixed size while all other columns are resizable.
Resizing of the column should affect the last column in the grid (like if i increase the size of a column the last column should get adjusted )
Quick help will be appreciated.
its about the webDatagrid
Are you asking about WinGrid or WebGrid? This is the WinGrid forum, so I don't know much about WebGrid. If this is a WebGrid question, I'd be happy to move your post to the appropriate forum for you, or you could just repost your question in the WebGrid forum.
