after having installed the application stylist add-in within VS2010, the following error was thrown:
Error code: 80131515 , Error message: unknownError text: The Addin Application Stylist Configuration Dialog cannot be loaded or raised an exception
I also found a solution for this issue:
edit file C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\devenv.exe.config, and add the following setting at the end of section <runtime>: <loadFromRemoteSources enabled="true"/>
Hello Stephan, Please let us know if you have any questions or need assistance with this issue.
Sincerely,
Swetha
