Has nobody else noticed that none of the WDM samples on the IG website work with IE8? I have tried with FireFox, Chrome and Safari and they are OK but with IE8 none of the sub-menus appear and none of the client-side events are firing.
Just thought you guys ought to know...
I'm using: Win7 ULT 64, IE8 8.0.7600.16385
Hi Paul,
I think you are running in IE8 Compatibility View. There is a know problem about that and it affects WebDataTree, WebDataMenu and WebExplorerBar controls. It is fixed in the first SR for 10.3. We plan to migrate the online samples to use the latest SR somewhere in December. In order to see the mode in IE8 go to Tools -> Developer Tools and check browser mode and document mode.
Hope this helps.
Lubomir
I'm still not seeing these examples correctly. Further furtling about reveals that it is not just the WebDataMenu that is misbehaving - most of the IG controls do not work. I have attached a screencam to show the problem and to also show my Internet Explorer settings
I just browsed the http://samples.infragistics.com/2010.3/WebFeatureBrowser/Default.aspx and tried the scrolling and non-scrolling samples they appear to work fine on IE8. Could you list the samples that you think are not working. There could be some networking glitch that affected Infragistics CDN, which caused some script to not be loaded, so this could be the original problem.
