860
Setting the active cell on adding of row
     I am adding a row.  I have a function that i call to validate the data in that row.  If it fails, it should active the offending cell.  When i do this, it appears not to get focus.  How do i fix this.
I have my RowAdding Event as follows
function
wdgQuestionare_Editing_RowAdding(sender, eventArgs) {
var row = eventArgs.get_row();
var isNotValid = Validate(row, sender);
eventArgs.set_cancel(isNotValid);
My Validate function:
function
Validate(row, grid) {
var cell = row.get_cellByColumnKey(
'QUESTION_ID');
var value = cell.get_value();
if (value == null || value == 0 || value == -1) {
   grid.get_behaviors().get_activation().set_activeCell(cell);
   return true;
What appears to be the problem,
  • 2677
    What version of NetAdvantage are you using?  I tried your exact code in a sample project using 10.3  and it worked fine.  I am not sure without debugging your sample to see what the problem is.  I have attached my sample project.  Please run it in your version and see if the problem persists.  If not, pleas try to modify my sample to reproduce the problem and send it back to me so I can take a look.  I removed the Ig_res folder to make the size small enough to fit as an attachment.  Just add that back to the project when it gets to you.
    I hope this helps.
    WebDataGrid_RowAdding.zip
