65
Does infragistics support Export to word in a Ultrawebgrid.
Does infragistics support Export to word in a Ultrawebgrid. I have seen Export to PDF,XPS and Excel but i have a requirement of exporting the data of a ultraweb grid to Word. Please help me out.
Thanks in advance.
  • 2677
    Infragistics does not have a control or API to export the grid to Microsoft word.  However, you can still do it, but you will need to do a little work.  One simple way would be to just write it out to ms word using an htmltextwriter.  This will throw all the contents of the grid into a word doc.  However, this will not look pretty because there will be no formatting.  Here is a simple code snippet.
    protected void Button1_Click(object sender, EventArgs e)
                Response.Clear();
                Response.ContentType = "application/ms-word";
                Response.AddHeader("Content-Disposition", "inline;filename=test.doc");
                Response.Charset = "";
                Response.Cache.SetCacheability(HttpCacheability.NoCache);
                StringWriter stringWriter = new StringWriter();
                HtmlTextWriter htmlTextWriter = new HtmlTextWriter(stringWriter);
                this.UltraWebGrid1.RenderControl(htmlTextWriter);
                Response.Write(stringWriter.ToString());
                Response.End();
    Another way would be to use a little COM Interop classes to create word objects and build the word table yourself.  Here is a good article that explains how to work with the Word objects in C#.  Hope this helps.  http://support.microsoft.com/kb/316384
    Aside from all these workarounds, you can submit a Feature Request for this new functionality.
