150
Ajax delete doesn't work
I try to implement deleting a row with Ajax, similar to this example: http://samples.infragistics.com/2010.3/WebFeatureBrowser/srcview.aspx?path=WebHierarchicalDataGrid/WebHierarchicalDataGrid_DeletingParentRow.src
When I click the Delete button I receive: "Async response failure: equest.readyState == 4". I use Version=10.3.20103.2013.
Sample code:
    <ig:WebHierarchicalDataGrid ID="whdg" runat="server" Height="400px"
        Width="700px" HeightAutoGenerateBands="False" AutoGenerateColumns="False" Key="LLL"
        AutoGenerateBands="False" DataKeyFields="Pk" InitialDataBindDepth="-1"
        InitialExpandDepth="2" ViewStateMode="Disabled">
        <Bands>
        </Bands>
        <Columns>
            <ig:TemplateDataField Key="Delete" VisibleIndex="0" Width="16">
                <ItemTemplate>
                    <asp:ImageButton ID="btnDelete" runat="server" CommandArgument='<%# Eval("Pk") %>'
                        AlternateText="Delete" ImageUrl="~/delete.gif"
                        CausesValidation="False" OnClientClick="DeleteRow(); return false;" />
                </ItemTemplate>
            </ig:TemplateDataField>
            <ig:TemplateDataField Key="Name" VisibleIndex="1">
                <ItemTemplate>
                    <asp:Literal ID="Literal1" runat="server" Text='<%# DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Name") %>'></asp:Literal>
                </ItemTemplate>
                <Header Text="name" />
        </Columns>
        <Behaviors>
            <ig:Selection CellClickAction="Row" RowSelectType="Single">
            </ig:Selection>
            <ig:EditingCore>
                <Behaviors>
                    <ig:RowDeleting />
                </Behaviors>
            </ig:EditingCore>
        </Behaviors>
    </ig:WebHierarchicalDataGrid>
    <script type="text/javascript">
        function DeleteRow()
            var grid = $find('<%= whdg.ClientID %>');
            var gridRows = grid.get_gridView().get_rows();
            var selectedRows = grid.get_gridView().get_behaviors().get_selection().get_selectedRows();
            for (var i = selectedRows.get_length() - 1; i >= 0; i--)
                var row = selectedRows.getItem(i);
                gridRows.remove(row);
    </script>
        public class TestObj
            private string _pk;
            private string _name;
            public string Pk
                get { return _pk; }
                set { _pk = value; }
            public string Name
                get { return _name; }
                set { _name = value; }
        public List<TestObj> L
            get { return (List<TestObj>)Session["TestObj"]; }
            set { Session["TestObj"] = value; }
        protected void Page_Load(object sender, EventArgs e)
            if (!IsPostBack)
                L = new List<TestObj>()
                    new TestObj() { Name = "Name1", Pk = "1" },
                    new TestObj() { Name = "Name2", Pk = "2" },
                    new TestObj() { Name = "Name3", Pk = "3" },
                    new TestObj() { Name = "Name4", Pk = "4" }
            BindGrid();
        private void BindGrid()
            Infragistics.Web.UI.DataSourceControls.WebHierarchicalDataSource whds = new Infragistics.Web.UI.DataSourceControls.WebHierarchicalDataSource();
            Infragistics.Web.UI.DataSourceControls.DataView view = new Infragistics.Web.UI.DataSourceControls.DataView();
            view.DataSource = L;
            view.ID = "L";
            whds.DataViews.Add(view);
            whdg.DataSource = whds;
            whdg.DataBind();
  • 14049
    There is probably an exception that occurred on the serve side. You can see the message if you look at the Net traffic in a firebug.
    We'll fix the message box in the next Service Release, sorry for inconvenience.
  • 19693
    Verified Answer
    Hello ppopov,
    You are using List<> as a DataSource.
    In this case you should handle RowDeleting event and manually delete the data.
    ViewStateMode="Disabled" onrowsdeleting="whdg_RowsDeleting">
    <ig:EditingCore AutoCRUD="false">
    protected void whdg_RowsDeleting(object sender, Infragistics.Web.UI.GridControls.RowDeletingEventArgs e)
            String key = ((Infragistics.Web.UI.GridControls.ControlDataRecord)(e.Row)).DataKey[0].ToString();
            L.RemoveAll(p => p.Pk == key);
            BindGrid();
    Please let me know if you need further assistance regarding this.
