215
Using the WHDG on an IPad
We are using the WHDG and need it to be able to run on an IPad via Safari.  While the grid renders fine on the IPad after the latest Service Release update to 10.3, I was wondering what the position is for using column grouping as the IPad doesn't appear to handle drag and drop?  Is there a gesture sequence I am missing that allows the Ipad to recognize the drag motion or would we be forced to use the Outlook style grouping in this situation?  As an alternative, would it be possible to add a button to the header of a column that would add the column to the group by in a future version?  Once a column is grouped the group header has and X button to remove each column from the group so it seems there would be one to add the column as well.
  • 2501
    Hello Cory,
    Thank you for submitting your inquiry to the Infragistics ASP.Net Forums.  Our Development Team is currently investigating support regarding using our controls with the IPAD and IPhone, but have not targeted support for a specific release date as of yet.
    What I will do, is open a support request for your inquiry, which may then be found under your account at Infragistics.Com. A Feature Request may then be submitted to our Development Team regarding your inquiry using the support request.
    Please use the following link to log onto your account at Infragistics.Com:
     <https://es.infragistics.com/Membership/MySupport.aspx>
    Once you are logged onto your account, go to My Support Activity to view the progress of this support request. An email notification will be sent to you through our support system with any new information regarding this inquiry.
    Thank you.
    Sincerely,
    Mike D.
    Developer Support Engineer
    www.infragistics.com/support
