215
Grouping/Column Moving in FireFox vs IE
I have a WHDG which allows for both column moving and column grouping.  In IE 8 the grouping works great but when trying to move a column left or right i just get a red circle with a line through it.  When I run the same grid in FireFox v. 3.6.12 I get the the reverse problem.  I can move the columns left and right but it doesn't allow dragging into the group by header.  Is this a known issue with the WHDG and these behaviors?
  • 33839
    Suggested Answer
    Hi leas3c,
    In 10.3 and below, Column Moving is not an officially supported behavior in the WHDG.  This support is planned for 11.1.  The problem is that the moving and grouping are using different drag behaviors, so one takes precedence and blocks the other.
    regards,
    David Young
