Ciao!
I have a grid in which I am using the available group by feature. The problem with this is that the remove button is placed in the wrong position when doing a mouseover over one of the group by items. Have a look at the enclosed image for more details...
Has anyone experienced anything similar, or has some solution for it? I amusing the grid inside a tab control...
/Henrik
Hello Zlantan, Thank you for your patience. I shall open a case and link this Issue. I will keep you posted on this.
Thank you,
Swetha
Excellent work all of you...! The problem is identified and I will wait for future releases...
Hi Henrik,
I was able to replicate the problem once I put the grid in the center tag. I have submitted this internally as 60107. If you contact Developer Support, you can be informed when this bug is fixed.
thanks,Dave
Hello Zlatan, I see very similar issue logged in our tracking system i.e. with 10.1 version but, this seems to be fixed. Can you please share your aspx and cs file in order for us to replicate from our end.
Upgrading to version 10.3 didn't help... The <center> tag might be the problem...
Any workaround for that?
/H
