I plan to make an agenda.
I have Infragistics 2010.2.
I have read the documentation on "Connecting WebSchedule to a Database in Visual Studio 2005" on http://help.infragistics.com/NetAdvantage/ASPNET/2010.2/CLR4.0/.
I have also read "Deploying to Microsoft SQL Server" for webSchedule.
My problem is that I don't see the sql installation script in NetAdvantage 2010.2\WebSchedule\Data (there is no sql script in Infragistics folder).
Can you redirect me on a recent or adapted documentation for webschedule (not with sample data, with an sql database).
Ok, all files are here, I missed to check in public documents.
Thank you, Benoit.
I just did a recent install of 10.2 and everything showed up. C:\Users\Public\Documents\Infragistics\NetAdvantage 2010.2\ASP.NET\WebSchedule\Data is the folder that contains 3 sql scripts and an access database. (Note: I chose "All Users" during the install and not "Just for me" otherwise pick your user folder instead of the public documents folder).
If they are not showing up for you then we need to gather more information.
