I have the trial version of "NetAdvantage for Web Client 2010 Vol. 2 Complete Bundle".
I am trying to use the webSchedule.
I don't see the webWeekView in my VS2010 (although I see WebScheduleInfo, WebMonthView, WebDayView, webCalendarView,...)
I have try to insert a webWeekView in the source code but it causes a tagPrefix not registered in the webForm error.
I will buy the product "NetAdvantage for .NET ".
Does I will get the webWeekView with the fully registered NetAdvantage for .NET ?
Regards, BDM.
Thank you, it works well!
Hello BDM,
You receive all of the controls in the trial version.
I like to sort my controls alphabetically (which you can do in the right-click context menu of the toolbox tab).
If it is not there, then right click the toolbox tab and select "Choose Items". It may take a while to load the dialog. From the "Choose Items" dialog, check (select) the WebWeekView assembly, or browse to it in the installation folder. Click OK, and you should now see the WebWeekView in the toolbox.
This help topic might also be of interest.
Let me know if you have further questions.
Elizabeth Albert
Localization Engineer
