245
WebDataMenu doesn't navigate to URL if alert or confirm is in client side javascript
I'm binding a WebDataMenu to an xml file like so:
<ig:WebDataMenu ID="TopNavigationMenu" EnableViewState="true" runat="server" GroupSettings-Orientation="Horizontal"
GroupSettings-ExpandDirection="Down" GroupSettings-AnimationType="ExpandAnimation"
GroupSettings-AnimationDuration="1" EnableTheming="True" >
<ClientEvents ItemClick="WebDataMenu1_ItemClick" />
<DataBindings>
<ig:DataMenuItemBinding DefaultText=" " TextField="Text" ValueField="Value"  ImageUrlField="ImageUrl"
                            KeyField="Key" NavigateUrlFields="Url" TargetField="Target" ToolTipField="Text" />
</DataBindings>
</ig:WebDataMenu>
 The client side javascript looks like this:
function WebDataMenu1_ItemClick(sender, e) {
            return confirm("Proceed with menu click?");
If I take the confirm line of javscript code out then clicking on a menu item goes to the proper url defined in the xml config file. With the confirm line in, it doesn't matter if I choose Ok or Cancel, the page remains the same. This behavior also occurs with alerts. Any help would be appreciated?
