915
Problem with Self Referencing Table as Source
I have created a WebHierarchialDataSource that uses a LinqDataSource which selects its data from a self referencing SQL Server table.
I have confirmed that the LinqDataSource is indeed brining back the data from the table and I have my relations setup property, but when I bind the WebHierarchialGrid it keeps telling me there are no rows to display.  I cannot figure out why.
I even tried this with a SqlDataSource and get the same results.
Here is my code for the webpage:
<ig:WebHierarchicalDataGrid ID="whdg1" runat="server" DataSourceID="WebHierarchicalDataSource2"
    AutoGenerateColumns="False" AutoGenerateBands="False" Height="350px" Width="99.7%"
    DataKeyFields="MgrID"
    ExpandableAreaCssClass="ighg_FeatureBrowserExpandableArea"
    DataMember="LinqDataSource2_DefaultView" IsSelfReference="True"
    Key="LinqDataSource2_DefaultView">
    <ExpandCollapseAnimation SlideCloseDirection="Auto" SlideCloseDuration="300" SlideOpenDirection="Auto"
        SlideOpenDuration="300" />
    <Columns>
        <ig:BoundDataField DataFieldName="EmpID" Key="EmpID">
            <Header Text="EmpID" />
        </ig:BoundDataField>
        <ig:BoundDataField DataFieldName="EmpName" Key="EmpName">
            <Header Text="EmpName" />
        <ig:BoundDataField DataFieldName="MgrID" Key="MgrID">
            <Header Text="MgrID" />
    </Columns>
    <EmptyRowsTemplate>
        <div style="text-align: center;">
            <br />
            <br />
            <img src="attention.png" align="middle" alt="Attention..." />
            No Destinations Found.
        </div>
    </EmptyRowsTemplate>
    <ErrorTemplate>
            <img src="error.png" align="middle" alt="Error..." />
            An error has occurred! Please contact support.
        </div>
    </ErrorTemplate>
</ig:WebHierarchicalDataGrid>
<asp:LinqDataSource ID="LinqDataSource2" runat="server"
    ContextTypeName="TestHTMLEditor.EmpDataContext"
    Select="new (EmpID, EmpName, MgrID)" TableName="Emps">
</asp:LinqDataSource>
<ig:WebHierarchicalDataSource ID="WebHierarchicalDataSource2" runat="server">
    <DataViews>
        <ig:DataView ID="LinqDataSource2_DefaultView" DataMember="DefaultView"
            DataSourceID="LinqDataSource2" />
    </DataViews>
    <DataRelations>
        <ig:DataRelation ChildColumns="EmpID"
            ChildDataViewID="LinqDataSource2_DefaultView" ParentColumns="MgrID"
            ParentDataViewID="LinqDataSource2_DefaultView" />
    </DataRelations>
</ig:WebHierarchicalDataSource>
Here is the code to create the table I am using:
USE [TestDB]
GO
/****** Object:  Table [dbo].[Emp]    Script Date: 10/21/2010 15:24:35 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
SET ANSI_PADDING ON
GO
CREATE TABLE [dbo].[Emp](
 [EmpID] [int] NOT NULL,
 [EmpName] [varchar](30) NULL,
 [MgrID] [int] NULL,
PRIMARY KEY CLUSTERED
 [EmpID] ASC
)WITH (PAD_INDEX  = OFF, STATISTICS_NORECOMPUTE  = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS  = ON, ALLOW_PAGE_LOCKS  = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
SET ANSI_PADDING OFF
GO
ALTER TABLE [dbo].[Emp]  WITH CHECK ADD FOREIGN KEY([MgrID])
REFERENCES [dbo].[Emp] ([EmpID])
GO
Here is code to insert data in to the table:
INSERT dbo.Emp SELECT 1, 'President', NULL
INSERT dbo.Emp SELECT 2, 'Vice President', 1
INSERT dbo.Emp SELECT 3, 'CEO', 2
INSERT dbo.Emp SELECT 4, 'CTO', 2
INSERT dbo.Emp SELECT 5, 'Group Project Manager', 4
INSERT dbo.Emp SELECT 6, 'Project Manager 1', 5
INSERT dbo.Emp SELECT 7, 'Project Manager 2', 5
INSERT dbo.Emp SELECT 8, 'Team Leader 1', 6
INSERT dbo.Emp SELECT 9, 'Software Engineer 1', 8
INSERT dbo.Emp SELECT 10, 'Software Engineer 2', 8
INSERT dbo.Emp SELECT 11, 'Test Lead 1', 6
INSERT dbo.Emp SELECT 12, 'Tester 1', 11
INSERT dbo.Emp SELECT 13, 'Tester 2', 11
INSERT dbo.Emp SELECT 14, 'Team Leader 2', 7
INSERT dbo.Emp SELECT 15, 'Software Engineer 3', 14
INSERT dbo.Emp SELECT 16, 'Software Engineer 4', 14
INSERT dbo.Emp SELECT 17, 'Test Lead 2', 7
INSERT dbo.Emp SELECT 18, 'Tester 3', 17
INSERT dbo.Emp SELECT 19, 'Tester 4', 17
INSERT dbo.Emp SELECT 20, 'Tester 5', 17
GO
