I have this message on my NetAdvantage controls in design mode: "Error Creating control for.Net (Full) Trial Period Expired".
I have upgraded the trial version with de Key but nothing changed...
Thanks for your help.
Nicolas
I have the same problem with NetAdvantage 2013.1.
I re-installed the application, with my licenses. And then ran the "Version Utility 2013.1".
- I upgraded the Solution. Then re-opened VS2019 Enterprise, and tried to open my MainForm, it said "NetAdvantage for Windows Forms Trial Period Expired." Ignore and Continue, did not open the GUI.
- I re-ran the Version Utility, and I chose "upgrad the Project". Then re-opened VS2019 again. And opening my MainForm, it still said the same thing.
Thanks!
Rerunning the installation solved the problem, and also my Javascript Intellisense is showing up again!
Arman
HI,
In order to get rid of the Trial LIcense message, Re run the installation with your license key.
Then run the project upgrade or version utility to upgrade any projects that were created with the trial version of the product.
Sincerely, Matt Developer Support Engineer
Same problem here with Netadvantage 2012.1. Trial has expired, I registered the key online, website and all the controls compile and run successfully
Thank you for your reply.
I tried your solution, but it did'nt work...
Here is a printscreen of the error. It's jsut a problem in design mode. I can use the control in the code mode, and I can run the solution.
Thank you
