I have a grid where I do inline editing on about 10 columns. Several of these columns have dropdown editors. When the grid is initially loaded it displays the text of the drop down and not the value. This is good. However, when a row is updated, the column display its value on return. (That is it looses it text display). How do we keep the text display? Is there something i can call on the grid provider or am i missing a property.
I have also same kind of issue.Could you please suggest me the solution of this problem?
Yes, i am still having the issue. I have attached the page in question.
Just checking if you still have issue with WebDropDown? If you post some code I will gladly look at it and provide you some suggestions.
Thank you
Hello Manuel,
could you post your markup code to see which properties are set.
