I want to know how can i change a header.
Since I set the header.repeat = true because i want it to continue till gridexport is done, supposed if five pages are assigned to the grid report it will have the same header, then the next page, I want a new header. What should i do??
The link refers to the forum post:
http://blogs.infragistics.com/forums/p/2862/82849.aspx
The reply by Tom Puglisi gives a detailed example.
Magued
Magued,
I do not see anything related to header. What I am trying to said is that I like to have each pages have different header, not the same header title. For instance if two pages have the same type of data, then it should print out that type of header, then the third page will have different type of data, then it should print out a new header on that third page. Is that possible??
Rob
Was the issue resolved? Do you have any questions that you would like to discuss?
Please refer to the following link for some suggestions regarding implementing multiple headers.
http://forums.infragistics.com/forums/p/46018/248987.aspx
