When setting a DataSource to an array of object and there sub objects within the object, how do you access the DataFieldName? I have tried:
DataFieldName="Customer.CompanyName"
but that does not seem to work and I can't find any example of this, so is this even supported?
Hello kmarkle,
The easiest way to do this is to create wrapper for the data you want in the grid and then create List<MyDataWrapperClass>. Then bind the grid to it.
Hope that helps.
Christo Djambov
If you provide DataSource for the grid which is an array of objects and autoGenerateColumns is equals to true the grid will generate its columns( BoundDataFields) based on the public properties of these object. Could you provide more information about your scenario, why you would like to get this in that way?
