865
Expanding/Collapsing Rows
Is there any way rows can be expanded/collapsed at the parent level using a hyperlink instead of an expand/collapse image?
  • 5739
    Here's some code for the client side expansion:
    var grid = ig_controls["WHDG"].get_gridView();
    var gridrow = grid.get_behaviors().get_activation().get_activeCell().get_row();
    gridrow.get_grid().get_rows().get_row(gridrow._index).set_expanded(true);
     Ed
  • 12679
    Let us know if you  need further assistance with this matter.
  • 33839
    Suggested Answer
    Hi craigmo,
    One option would be to add a template column to the parent band that has a hyperlink with a client click handler that expands the row.  You would have to hide the default expansion column.  Currently, there is no way to hide it.  You might be able to set a css for the EpansionCell, but that could be applied to all bands (if you have a third band and wanted the regular expansion buttons on the second level), so you might need to handle the initialize event and simply set display none to the expansion cell on the root rows.
    regards,
    David Young
