How can I format the values at the bottom of the chart, furthermore is it possible to change them, such as 100k, 100million, etc...??
Hello Scott,
You can format values on x axis by setting the TickmarkPercentage property of the X axis. You also have to set Range type and minimum and Maximum value on X axis.The following lines of code will achieve the described functionality:
this.UltraChart1.Axis.X.RangeType = Infragistics.UltraChart.Shared.Styles.AxisRangeType.Custom;this.UltraChart1.Axis.X.RangeMax = 10000000;this.UltraChart1.Axis.X.RangeMin = 0;this.UltraChart1.Axis.X.TickmarkPercentage = 10;
The above lines of code will show the value on X axis as 1000000, 2000000 and so on. This value is 10 percentage of maximum value.
The following link will give you more details on TickmarkPercentage property:<http://help.infragistics.com/NetAdvantage/ASPNET/2010.2/?page=Infragistics4.WebUI.UltraWebChart.v10.2~Infragistics.UltraChart.Resources.Appearance.AxisAppearance~TickmarkPercentage.html>
Hope this helps.
Bhadresh
