A two level grid TOP and MIDDLE
I am binding manually, all works fine. Except that I want to have the Child Grids'a ADD Row ( ParentKey ) already filled in with the ParentRow's ParentKEY.
I thought I could use the RowsIslandsPopulated event for this, but I am not sure how to get the value into the ADD Row Row which appears at the bottom ?
But this link does
http://help.infragistics.com/NetAdvantage/ASPNET/2012.2?page=WebHierarchicalDataGrid_Hierarchical_View.html
this link no longer works:
http://help.infragistics.com/NetAdvantage/ASPNET/2010.2?page=WebHierarchicalDataGrid_Hierarchical_View.html
Hello soberly,
Let me know if you need further assistance regarding this
Hello Soberly,
You are on the right way to achieve this.
This can be done using RowIslandsPopulated event by the following way :
protected void WebHierarchicalDataGrid1_RowIslandsPopulated(object sender, Infragistics.Web.UI.GridControls.ContainerRowEventArgs e)
ContainerGrid childGrid = this.WebHierarchicalDataGrid1.GridView.Rows.FromKey(e.Row.DataKey).RowIslands[0];
object[] parentKey = childGrid.ParentRow.DataKey;
GridRecord addRow = childGrid.Behaviors.EditingCore.Behaviors.RowAdding.Row;
// I want to fill the second cell with the ParentKey
addRow.Items[1].Text = parentKey[0].ToString();
For more information regarding accessing row islands or parent rows (both server or client side) please
refer to the online documentation:
Let me know if you need further assistance.
