315
Gantt bars not aligning when containing half-hour increments
This is a composite gantt + line chart.
Note that the first (golden) "gantt bar" is supposed to run from 6:30 to 9:00. However, visually it starts at 6.
The 3rd (green bar) should go from: 3 to 4 AND from 4:30 to 9:30.
Incidentally, when I render data that does NOT contain half hour values, everything appears perfectly.
Thanks in advance.
  • 315
    Verified Answer
    I think I have found the solution.
    As it turns, in the image above, the XAxis is actually display 6:30 A as the start time. Due to my format string it was not displayed.
    Based on that, I figured that setting the range min/max would give me the desired results. And it did.
    I used the following lines:
                axisX.RangeType = AxisRangeType.Custom;
                axisX.RangeMin = new DateTime(2010, 9, 7, 6, 0, 0).Ticks;
                axisX.RangeMax = new DateTime(2010, 9, 8, 0, 0, 0).Ticks;
