Hi Everybody,
I am using NetAdvantage 2008 vol 1(CLR 2)
In my local machine all the controls working properly(infragistics) but once upload all my files to sever(hosting). Any how its getting error.
I had upload all the relevant folder & files.
Error displays like : System.Security.SecurityException: That assembly does not allow partially trusted callers
Please help me...
Saravanan Srini
saravanan@vesttechnologies.com
See my previous post and submitt an incident to Developer Support
Hi
Thanks for your reply...
I done the above procedure what you said in your mail Deploying an Application to a Partial-Trust Environment any how it displays the same error..
Description: The application attempted to perform an operation not allowed by the security policy. To grant this application the required permission please contact your system administrator or change the application's trust level in the configuration file. Exception Details: System.Security.SecurityException: That assembly does not allow partially trusted callers. Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
[SecurityException: That assembly does not allow partially trusted callers.] Infragistics.WebUI.Shared.UltraLicenseAttribute..cctor() +0
What should I do now ?
saravanan
See the help topic "Deploying an Aplication to a Partial-Trust Environment" and use the set of assemblies that should have been installed with NetAdvantage that have been marked with the AllowPartiallyTrustedcallersAttribute
If that doesn't work contact developer support for help.
