I can not get the DLLs in the Bin folder so I can select them to be copied local to deploy on a web server. Any suggestions o how to do this?
I am using VS 2010 .Net Framework target 4.0 and Infragistics 10.2
Hello Jody,Thank you for submitting your inquiry to the Infragistics ASP.Net forums. The following article from our online help documentation of NetAdvantage for ASP.NET 2010 Volume 2 Target Framework CLR 4.0 provides information with links to other articles to explain how to deploy our ASP.NET resources to a web server:Deploying Your Application<https://es.infragistics.com/help/aspnet/web-deploying-a-web-application-that-uses-netadvantage-for-asp-net-controls>Deploying Common Assets<https://es.infragistics.com/help/aspnet/deploying-common-assets>
Copying the DLLs to the server bin folder will make the application work. AS a side note, you do not need to install the NetAdvantage for ASP.NET toolset to the web server to be able to use the controls.Please let me know if this information is helpful or if you require further assistance.
Thank you.
Sincerely,Mike D.Developer Support EngineerInfragisticshttps://es.infragistics.com/support
