Hi Team,
I have added the ToolTip to each cell with its data with client side script. But it causes unresponsive script occasionally. So can i do the same while the databinding time on server side. And the AutoGenerateColumns property is set to true.
Any help will be greatly appreciated.
Assyst
Hi Assyst,
Let us know if you have further questions with this issue.
Lyuba
Developer Support Engineer
www.infragistics.com/support
Currently it is not possible to add the tooltips on the server. If you would like to see this in our future versions you can submit a feature request here:
http://devcenter.infragistics.com/Protected/RequestFeature.aspx
