I had read in a previous post that it was recomended to use the event ResourcesFetched to limit down the visible resources. The potential problem is that this could be a performance issue loading all of the various resources.
After looking through the source code for the WebScheduleInfo control I noticed how you check the Visible Resources Count when doing the Databind().
I figured that if I set the visible resources that I am interested in prior to doing the Databind check I should be able to only show out the resources I am intrested in instead of loading all the resources then limiting them inside the ResourcesFetched event.
What I would like to do is extend out the WebScheduleInfo then override the DataBind method so that I can add 1..n resources into the VisibleResources Collection then call the base DataBind mentod. I used the following code below to do just that (hard coded a single param for now) then dropped the new user control onto the page in place of the WebScheduleInfo control. From what I can tell this appears to work.
The only part that I am still wondering about is how the WebScheduleInfo control and the WebScheduleSqlClientProvider play together with regards to what I am trying to accomplish (performance minded).
public partial class WebScheduleInfoExt : WebScheduleInfo { public override void DataBind() { Resource o1 = new Resource(); o1.Key = "1"; o1.Name = "Darren Straube"; this.VisibleResources.Add(o1); base.DataBind(); } }
