some times my dataset has only one column of data to display on the chart so I sould have some thing like this (As in Excel):
but a similar result with Infragistics line chart gives us (the data is in the grid after the chart):
Why we can not have only points, instead of lines?
I'm using this version 9.1.20091.2055
I hope there is a solution or a work around to this.
Tks
Zakia
Hello Zakia,
Let me know if you have further questions with this matter.
Have you read the documentation link which I sent you?
You will find the answer to your question there :
Let me know if you need more help.
I don't think a scatter chart, because in case, I have more than one value I want to have some thing like this:
So I need a lineChart.
As I can see from your images you are looking for a Scatter Chart.
Here is the link to the online samples showing the Chart Gallery
http://samples.infragistics.com/2010.2/WebFeatureBrowser/WebCharts/Gallery/Scatter/Scatter.aspx
http://samples.infragistics.com/2010.2/WebFeatureBrowser/contents.aspx?showCode=true&t=WebCharts/Gallery/TwoDChartGallery.aspx~srcview.aspx?path=../WebFeatureBrowserVB/WebCharts/Gallery/TwoDChartGallery.src~srcview.aspx?path=WebCharts/Gallery/TwoDChartGallery.src
Below there is a helpful link to the online documentation:
http://help.infragistics.com/NetAdvantage/ASPNET/2010.2?page=Chart_Scatter_Chart.html
Let me know if you need more assistance regarding this.
P.S : You have submitted this question in the Grids forum thread. Please send your requests rearding WebChart in the WebChart forum. This way you will receive quickly competent help
http://community.infragistics.com/forums/64.aspx
