I am using UltraWebGrid version 9.1, and I want to show the footer below the grid which will show something like: "Displaying records 10 of 2810". Now, I am trying to add a checkbox column. The problem is that when I add the checkbox column after all my dataset columns have been bound, the footer is displayed perfectly. However, when I try to add the checkbox column before the other columns (i.e. if it is the first column) then the footer is not displayed. Please help.
Thanks.
Rimi
Hi Rimi,
I've created a support ticket which can be seen under your profile with number CAS-48852-691Z2T. Please provide sample showing this issue also "steps to reproduce " and we will investigate this further.
No, still looking for a solution.......
Can't paste my code here, for security reasons. Is it fine if I send the screenshots of the issue to illustrate the problem?
Did you get this resolved?
Hello Rimi,
I will need more information about this. Could you provide running smple showing this issue. You can attach it here.
