860
Ajax Web Dialog Window Default Styles
When attempting to add the WebDialogWindow control to an asp page.  Infragistics attempt to import styles to a default location in web project.  Why is it creating the /ig_res folder here?  Should this be in /ig_common somewhere?  What is the most appropriate IIS setup for this?
  • 24497
    Verified Answer
    If you running IIS application and need to keep all css resources in IIS, then you may create a virtual directory and set it to styleSetPath. Example:
    1. Create c:\inetpub\wwwroot\aspnet_client\infragistics\ig_res10.2 and set its name or virtual directory to "ig_res10.2"
    2. Copy there style sets used by your application (from ig_res):
     c:\inetpub\wwwroot\aspnet_client\infragistics\ig_res10.2\Default\*.css
     c:\inetpub\wwwroot\aspnet_client\infragistics\ig_res10.2\Default\images\*.imageFiles
    3. web.config:
     <infragistics.web enableAppStyling="true" styleSetName="Default" styleSetPath="http://localhost/ig_res10.2/"/>
