Hey Guys,
Hopefully you can help me figure this out. I'm working in VS 2008. I'm creating a web form with a listview that takes a datatable as a datasource. The datatable adds images to the listview.
What I need to do is to be able to drag an image onto a div which is acting as my drop target. Then, the user should be able to drag any image from the drop target onto a garbage can icon and remove it from the drop target. Every time an image is dropped onto the drop target, or dragged off for removal, a hidden field will be updated with the file ids for use in saving them in a folder elsewhere.
Parts of it are working. For example I can drag an image onto the target area, and it gets added to the list in the hidden input. But, if I try to drag it over second div acting as my garbage collection drop area, I get a ghost image of the entire drop target moving with my mouse.
I believe the images should be wrapped in individual divs to correct that. My problem is that I have just started working with drag and drop and my javascript experience doesn't cover anything like this.
Any really good, basic examples you know of that would help me out here?
I can figure out how to update the list of images, etc. I need a better handle on the drag and drop part.
Thanks in advance
I've got it working guys. We can close this one.
I'm farther along. I can drag and drop images from my listview onto my target area. I have it working so that they disappear from the listview when dropped, to show that the user can't have multiple copies of the same image in the list.
I am also able to drag from the drop target to another div that I am using as a trash collection spot. when I do, the image disappears from the list in the drop target which is fine, but then the javascript blows up in the remove handler.
I'm using a variation on the shopping cart demo on the Infragistics page that demonstrates the drag and drop framework.
My source code for my ascx file where the listview is looks like this:
table id="ImageViewer1" style="width:100%;
<tr
<td style="background-color:#E1E1E1;border:2px solid #525051;padding:2px;
<asp:ListView ID="lvImages" runat
="server">
<LayoutTemplate
<asp:DataPager ID="dpImages" runat="server" PagedControlID="lvImages" PageSize="4"></asp:DataPager
<div id="itemPlaceHolder" runat="server"
</LayoutTemplate
<ItemTemplate
<div style="border:2px outset;margin:10px;padding:2px;text-align:center;float:left;width:200px;
<img src='<%# Eval("ThumbnailUrl") %>' downloadUrl='<%# Eval("Url") %>' style="height:150px;width:150px;margin:2px;" imageId='<%# Eval("asset_id") %>' id='<%# Eval("asset_id") %>' /><br
<span><%# Eval("Name") %></span><br
<span>Source: <%# Eval("Source") %></span
</div>
</ItemTemplate
</asp:ListView><br
<div id="trashCollection" style="width:100px; height:100px; border-style:dotted;right:-60px; border-color:Black" runat="server"></div
</td
<td style="text-align:center;width:250px;
<div style="background-color:palegreen;border:2px inset;overflow:scroll;padding:2px;height:600px;text-align:center;width:250px;" id="dropTarget" runat
</div><br
<asp:Button ID="btnSave" runat="server" Text="Save selected images"
onclick="btnSave_Click" /><br
<a href="CurrentImages.aspx" target="_blank">View existing images</a
</tr
<tr>
<td
table>
The listview is databound to a table with the images data. The javascript looks like this:
function
InitViewer(viewerId)
var manager = null;
viewer = $get(viewerId);
var dropTarget = $get(viewerId + "_dropTarget");
var ddb = new
$IG.DragDropBehavior();
var list = viewer.getElementsByTagName("IMG");
var panel = $get(viewerId + "_dropTarget");
for (var i = 0; i < list.length; i++)
ddb.addSourceElement(list[i],
true);
var dropHandler = function(sender, e) {
manager = e.get_manager();
var source = e.get_manager().get_source().element;
var imageList = $get(viewerId + "_imageList");
if (imageList.value != null && imageList.value.length > 0)
imageList.value +=
imageList.value += source.getAttribute(
"imageId");
panel.appendChild(source);
var removeBehavior = null;
var ddb = removeBehavior;
if (!ddb)
removeBehavior = ddb =
new $IG.DragDropBehavior();
ddb.addTargetElement($get(viewerId +
"_trashCollection"), true);
ddb.addDragChannels([
"trash"]);
ddb.addDropChannels([
ddb.get_events().addDropHandler(removeHandler);
ddb.addSourceElement(source);
"_dropTarget"));
ddb.get_events().addDropHandler(dropHandler);
var removeHandler = function (source, evntArgs)
var eleID = evntArgs.get_manager().get_source().element.id;
panel.removeChild( document.getElementById(eleID) );
viewerId = the name of the table in the source code for the ascx file ("ImageViewr1").
When I drag and drop from my target area to the trash collection area, it appears to go Ok. The image disappears from my list in the target area, then it breaks on this line:
The error reads: Microsoft JScript runtime error: 'get_manager().get_source().element' is null or not an object.
Any ideas what's wrong?
Thanks again.
