Hi
When I click to cell in UltraWebGrid, it shows rectangle across it.
Can any body tell me how to hide the rectangle on cell selection.
Sandip
Hello Sandip,
This rectangle is most probably caused by Selection or Activation behavior of the grid.
If this is caused by activation - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebGrid_Activation_Object.html - you can disable it or change the appearnace of the activated cell:
<DisplayLayout …>
<ActivationObject AllowActivation="true" BorderColor="" BorderWidth="">
</ActivationObject>
</DisplayLayout>
http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/WebGrid_Use_Cell_Selection_and_the_Active_Cell.html
If this is caused by selection - http://help.infragistics.com/Help/NetAdvantage/ASPNET/2010.3/CLR4.0/html/Infragistics4.WebUI.UltraWebGrid.v10.3~Infragistics.WebUI.UltraWebGrid.UltraGridLayout~SelectTypeCellDefault.html - you can change the selection appearance also.
