I'm using the WebDropDown version 10.2.20102.1011 and i'm loading it with items in greek language. Everything works fine in firefox. When i'm using the Internet Explorer and typing inside the WebDropDown, in order to user the auto complete feature of the WebDropDown, the Internet Explorer crashes. That happens when the word i'm typing exists in the list of the WebDropDown. I'm using Internet Explorer 8.0.6001.18702 and Firefox 3.6.3.
Could you please help me with this problem because it is very very critical for me!
Here is a simple asp.net page that happens this problem:
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="Default.aspx.vb" Inherits="webdropdowntest2._Default" %><%@ Register Assembly="Infragistics35.Web.v10.2, Version=10.2.20102.1011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.ListControls" TagPrefix="ig" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" ><head runat="server"> <title></title></head><body> <form id="form1" runat="server"> <div> <asp:ScriptManager ID="ScriptManager1" runat="server"> </asp:ScriptManager> <ig:WebDropDown ID="WebDropDown1" runat="server" Width="200px"> </ig:WebDropDown> </div> </form></body></html>
The CodeBehind file is the following:
Partial Public Class _Default Inherits System.Web.UI.Page Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("ααα", "10")) WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("ΑΑΑ", "11")) WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("βββ", "20")) WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("ΒΒΒ", "21")) WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("ηηη", "30")) WebDropDown1.Items.Add(New Infragistics.Web.UI.ListControls.DropDownItem("ΗΗΗ", "31")) End SubEnd Class
Thanks in a advance,
Leo
Hello Leo,
A support request has been opened for this inquiry. This issue will be logged with Development for further research. A notification will be sent to you through our support system with any new information regarding this issue.
Please use the following link to log onto your account at Infragistics.Com:
<https://es.infragistics.com/Membership/MySupport.aspx>
Once you are logged onto your account, go to My Support Activity to view the progress of this support request. Please let me know if you have any questions.Thank you.Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
Thank you for your patience. We shall review this behavior and log in our tracking system for a fix.
We appreciate your cooperation and time.
I was able to reproduce the issue with Japanese data (since I have the Japanese language pack installed).
I have created a case for you. If you do not receive any notifications about the case within the next week or so, please reply to this post and I will follow up with the manager of developer support.
Elizabeth Albert
Localization Engineer
The ff works fine but IE doesn't.
I'm using IE ver 8.0.6001.18702 and visual studio 2008 with .net 3.5 SP1
The operating system is windows XP sp3 (English Interface with Greek regional settings)
When I'm typing the first letter of a word that exists in the webDropdown the IE crashes but if I type a letter that no word starts from this the IE doesn't crash.
The steps to reproduce are the following:
1)Run with IE the webapplication (the two files i posted in my first post)
2)Mark the text inside the webDropdown and press delete
3)Set your keybord to greek or copy the greek letter "α"
4)Paste or type the letter "α" in the webDropdown
5)The IE will crash
I hope that you can reproduce it!
Thank you,
Hello leodata, I tested your application and was unable to reproduce this issue. IE and FF doesn't crash and works just fine. Could you please provide more information regarding Operating System used, Visual Studio version used.
Swetha
