85
Spline Chart - Group x-axis by days/months
I have created a spline chart, which displays a datetime column along the x-axis and 2 quantity columns on the y-axis (double). I am using the AxisIntervalType to control the tick mark intervals (i.e. days) and I am able to format the x-axis lables as follows: <ITEM_LABEL:dd/MM/yyyy>.
This all works fine, however, I would like to group the chart by number of days and display the number of days along the x-axis. Is this possible? Can this be achieved by changing the format of the item label to calculate days?
DataTable testData = new DataTable();
testData.Columns.Add("DateSent", typeof(DateTime));
testData.Columns.Add("Quantity1", typeof(double));
testData.Columns.Add("Quantity2", typeof(double));
Attached screenshot is what I currently have. I would ideally like to represent datetime values with number of days, and if this is possible extend this to be able to switch the view to group by weeks/months etc.
Any help would be most appreciated.
Jon
  • 26458
    You can change the date strings to pretty much anything if you use IRenderLabel interface. There should be a large number of examples on these forums and in our online help.
    First, you add this to your page_load:
    Hashtable labelHash = new Hashtable();
    labelHash.Add("CUSTOM", new LabelRenderer());
    ultraChart1.LabelHash = labelHash;
    ultraChart1.Axis.X.Labels.ItemFormatString = "<CUSTOM>";
    Then, create the following class:
    public class LabelRenderer:IRenderLabel
     public string ToString(Hashtable context)
      DateTime dateLabel = (DateTime)context["DATA_VALUE"];
      return dateLabel.Day.ToString();
    This particular code snippet replaces the date label on the x axis with the day of the month, but you can change it to anything you like.
