When I printing a WebGrid the Arabic Language in PDF Not Correct displaying ; Characters are not connected with each other
Please look at PDF in attachments ..
Hi Sameh,
The document export engine doesn't support right-to-left or bi-directional strings. There is no way to export strings - you can only export individual characters. That is the reason for the behavior you are experimenting.
This feature maybe available in future releases. Please update the forum regarding any questions.
Magued
please see attached sample
Thanks for the screen shots. How are you loading the data to the grid, can you attach a small sample that reproduces the issue or attach the datasource that you are using?
It is WYSIWYG (What-You-See-Is-What-You-Get). The PDF output should look the same as the what is in the grid. if that is not the case then please send me more information about how you are populating the grid.
