I have a webhierarchical datagrid with one parent level and one child.
Outside of this whdg, I have a toolbar with edit, save and cancel buttons.
By default, when I display my page, I would like to have the cell(4) non editable for all childs levels.
When I click on my edit button, I would like to edit cell 4 for all rows in child level. When I click save button, I would like to recover the new data server side in order to save data, then make my cells non editable.
In my grid, I have this:
<ig:WebHierarchicalDataGrid ID="GridSampleSize" runat="server" AutoGenerateBands="False" AutoGenerateColumns="false" EnableAjax="true" Height="450px" Width="746px" DataKeyFields="MAINKEY,SAMPLESIZE,PHASE" ClientEvents-Initialize="gridInit"> <AjaxIndicator Enabled="False" /> <ClientEvents RowExpanded="rowExpanded"/> <Columns> <ig:BoundDataField DataFieldName="PHASE" Key="PHASE"> <Header Text="<%$ Resources:Labels, lblPHASE %>" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="APPROVED" Key="APPROVED"> <Header Text="APPROVED" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="REJECTED" Key="REJECTED"> <Header Text="REJECTED" /> </ig:BoundDataField> </Columns> <Bands> <ig:Band AutoGenerateColumns="False" DataMember="dsMeasSampleSizeEnfant2_DefaultView" Key="dsMeasSampleSizeEnfant2_DefaultView"> <Columns> <ig:BoundDataField DataFieldName="POINT" Key="POINT" Width="50px"> <Header Text="<%$ Resources:Labels, lblPOINT %>" /> </ig:BoundDataField> <ig:BoundDataField Width="250px" DataFieldName="DESCRIPT" Key="DESCRIPT"> <Header Text="<%$ Resources:Labels, lblDESCRIPT %>" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="TOLERANCE" Key="TOLERANCE" Width="50px" DataType="System.Decimal"> <Header Text="<%$ Resources:Labels, lblTOLERANCE %>" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="SIZE" Key="SIZE" Width="50px" DataType="System.Decimal"> <Header Text="SIZE" /> </ig:BoundDataField> <ig:BoundDataField DataFieldName="SUPVAL" Key="SUPVAL" Width="140px" DataType="System.Decimal"> <Header Text="<%$ Resources:Labels, lblSUPVAL %>" /> </ig:BoundDataField> </Columns> <Behaviors> <ig:EditingCore> <Behaviors> <ig:CellEditing EditModeActions-EnableF2="true"> <ColumnSettings> <ig:EditingColumnSetting ColumnKey="POINT" ReadOnly="true" /> <ig:EditingColumnSetting ColumnKey="DESCRIPT" ReadOnly="true" /> <ig:EditingColumnSetting ColumnKey="TOLERANCE" ReadOnly="true" /> <ig:EditingColumnSetting ColumnKey="SIZE" ReadOnly="true" /> <ig:EditingColumnSetting ColumnKey="SUPVAL" ReadOnly="true" /> </ColumnSettings> </ig:CellEditing> </Behaviors> </ig:EditingCore> </Behaviors> </ig:Band> </Bands> <Behaviors> <ig:Sorting> </ig:Sorting> </Behaviors> <Behaviors> <ig:Activation ActiveRowCssClass="igg_ActiveRow" ActiveCellCssClass="igg_ActiveCell" Enabled="true" /> </Behaviors></ig:WebHierarchicalDataGrid>
And in code behind, when I click on edit, I have this line:
GridSampleSize.Bands["dsMeasSampleSizeEnfant2_DefaultView"].Behaviors.EditingCore.Behaviors.CellEditing.ColumnSettings["SUPVAL"].ReadOnly = false;
But my cell is always readonly.
Where is my error?
Thanks for your help.
Best Regards
Damien
This fix was released in the latest service release for 10.1, 10.2, and 10.3. One thing to note is that in order to carry over the changes from the Band to the ContainerGrid, WebHierarchicalDataGrid1.RefreshBehaviors() should be called.
Hi Dinesh,
Thanks for this. Do you have some delay to communicate about the new release?
Thank you.
Hi Damien,
I have tested your issue and I was able to reproduce it. I have logged a bug #34726 for this. You will be notified when a fix/workaround is released for this issue. Thanks.
