How do I add WebDataMenuItem dynamically to a webdatamenu control during load?
Hello
1 protected void Page_Load(object sender, EventArgse)
2 {
3 this.menu1.Items[0].Items.Add(
4 new DataMenuItem { Text = "Dynamic Robo at last position" }); ----- throws an error saying
ARUGMENTOUTOF RANGEEXCEPTION WAS HANDLEDBY USER CODE
INDEX WAS OUT OF RANGE. MUST BE NON-NEGATIVE AND LESS THAN THE SIZE OF THE COLLECTION
5 this.menu1.Items[0].Items.Insert(0,
6 new DataMenuItem { Text = "Dynamic at first position" });
7 this.menu1.Items[2].Items.Add(
8 new DataMenuItem { Text = "Dynamic Child" });
9 }
NEED SOME HELP IN SOLVING THIS ISSUE
THANKS
Hello Sanjay,
Fill free to write us if you have any questions with this matter.
Thank you.
The first thing to know is that you can only add dynamic items to a non-bound WebDataMenu. If you have a WebDataMenu which is bound to some data source, the best way to achieve that is to manipulate the data source itself.
Here is how to dynamically add items to a non-bound WebDataMenu:If we assume we have this menu defined in the markup (.aspx file):
1 <ig:WebDataMenu ID="menu1" runat="server">
2 <Items>
3 <ig:DataMenuItem Text="R2/D2" >
4 <Items>
5 <ig:DataMenuItem Text="Robo R2" />
6 <ig:DataMenuItem Text="Robo D2" />
7 </Items>
8 </ig:DataMenuItem>
9 <ig:DataMenuItem Text="Root Item">
10 <Items>
11 <ig:DataMenuItem Text="Child Item 1" />
12 <ig:DataMenuItem Text="Child Item 2" />
13 </Items>
14 </ig:DataMenuItem>
15 <ig:DataMenuItem Text="Root Item 1">
16 <Items>
17 <ig:DataMenuItem Text="Child Item 1">
18 </ig:DataMenuItem>
19 <ig:DataMenuItem Text="Child Item 2">
20 </ig:DataMenuItem>
21 </Items>
22 </ig:DataMenuItem>
23 </Items>
24 </ig:WebDataMenu>
Then we can use the Page Load event to add items dynamically in the following way:
1 protected void Page_Load(object sender, EventArgs e)
Please note the the WebDataMenu object, as well as any DataMenuItem object does have an Items collection (of type DataMenuItemsCollection). This is zero-based list of WebDataMenuItem objects which you can manipulate.
