I've adapted some earlier form code for a client side search using the latest 2010.1 code.
The tree correctly selects the appropriate node, but does not scroll that node into view.
How can I scroll the selected node into focus?
Best regards,
Paul
I need to do a similar thing, but I really want to do this from the server side. I am converting a ultrawebtree to a webdatatree and need to have an equivilent command for:
wdtDept.ScrollNodeIntoView(findNode)
where findNode is the node located within the tree.
I would appreciate any help on this...
Joel WZ
The solution above works only for a maximised screen. When I questioned this, I got this response (which also doesn't fully work).
Posted here so that anyone else searching can read the complete thread...
Hello Paul,
After some research, this issue has been determined to be a new feature request. But I also have a workaround you can use in the meantime.
The workaround is to use
node._element.scrollIntoView(tree);
I have attached a simple sample using this method. Please note this sample only searches for root nodes in the tree.
Additionally, I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR12405.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Please let me know if you have any other questions.
Sincerely,ValerieDeveloper Support EngineerInfragistics, Incwww.infragistics.com/support
I am just checking about the progress of this issue.
Did you solve your issue accordingly the information that I provided to you?
Let me know if you need any further assistance.
LyubaDeveloper Support Engineer Infragisticswww.infragistics.com/support
You can scroll the selected node into focus by calling the scrollIntoView javascript function for the element of the node:
tree.get_selectedNodes()[0].get_element().scrollIntoView();
Lyuba Petrova
